Ok, I have a lot of DVD-Rips and i want to convert them to SVCD's, but I'm not sure what resolution to convert them at, because they're wide screen...
any information will be greatly appreciated, thanks
You're confusing resolution w/ display aspect ratio. Common DAR include: 1:1 PC, 4:3 TV, 16:9 Movies. However, you can have these DARs at any resolution. Here's the problem, your TV has a DAR of 4:3 ONLY. To display a 16:9 source you have to use widescreen/letterboxing. The SVCD standard resolution is 480x480. You can have/add the black bars to the top/bottom of the screen to preserve the original aspect ratio.
If you are using TMPGenc, load your desired template and source. Then click on settings, then click on the advance tab and choose:
Source Aspect ratio: 16:9 525 line NTSC
Video arrange method: Full Screen (Keep Aspect Ratio) -
Ok, thanks for the info
but I'm gonna use the method involving Cinema Craft Encoder, what do i do for that?
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
Mix fullscreen and wide screen in DVD Lab?
By stantheman1976 in forum Authoring (DVD)Replies: 24Last Post: 27th Jun 2008, 22:11 -
wide screen question
By breeze9 in forum Video ConversionReplies: 3Last Post: 17th Feb 2008, 16:46 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41
