Hi there! I use my miniDV and Digital camera on vacations. Is there anyway(software/settings) that I can use to combine both video (from the miniDv) and pictures (from my digicam), chronologically to form a single video stream which I intend to burn on a DVD later? I reckoned that perhaps a software would be able to analyze the time of picture/video taken from the exif/timecode info stored in the JPEG and DV-AVI files respectively. Is this possible? (I've apparently gotten tired of watching the videos and pics of the same event separately!) Thanks!
Hi,
The compilation would need to be done in some kind of editing software. I use Premiere Pro 1.5 and I'm not aware of any "arrange on the timeline by date" function.
The closest I reckon you'll get is to be able to list your source files chronologically and then drag them onto the timeline in the order they're listed.
Just make sure that your date / time is set correctly and in synch on both cameras!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Ulead Video Studio 9 does this easily. Open a new project and import your DV clips and JPEg photos and insert them into the timeline however you choose and you can easily choose the length of photos displayed. You can also easily add canned audio that comes with the editor or add your own audio track. When you're done choose the share option and output whatever format you want. I advise outputting as DV AVI and using a separate encoder. Ulead is a great editor for amateurs, but the built in encoder sucks IMHO.
JPG to 18-hour video
By Aidan128 in forum Video ConversionReplies: 7Last Post: 18th Feb 2011, 07:21 -
Blending Images(jpg) together
By Soixante in forum EditingReplies: 11Last Post: 24th Jan 2011, 19:28 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 10:06 -
jpg to mpg
By dona in forum Video ConversionReplies: 3Last Post: 9th Dec 2007, 14:45 -
Refresh jpg
By bendixG15 in forum TestReplies: 2Last Post: 16th Oct 2007, 05:30
) Thanks!
