Results 1 to 9 of 9
  1. Banned
    May 2006
    Like using the TMPGenc DVD Author V1.62 very much. Usually, use I would go with the steps of Start >> Source Setup >> Create Menu >> Output
    How can I put the Menu in font instead of the back ?
  2. do you mean you want to create the menu first?....not sure I follow
    Mar 2004
    I believe the answer to your question is that you need the source to create internal structure, and determine links for the menu. So the source comes first.
  4. Banned
    May 2006
    Yes, usually using TMPGenc the menu setup comes after the Source, I usually end up with the DVD with the Menu at the very end. how can I put it in the front?
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How do you know exactly where TDA puts the menu?
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Methinks you're confusing the order in which you author things with the way the playing order is constructed.
    Is a better way of phrasing what you wish to do is that you want the menu to display on insert of the disc, instead of playing the first track on insert and then displaying the menu once this is finished ?
    If in doubt, Google it.
  7. Banned
    May 2006
    Correct, and how do I accomplish that please?
  8. In the "CREATE MENU" screen on the right side there will be a pull down menu called "FIRSTPLAY ACTION." Make sure that is set to "DISPLAY MAIN MENU."
  9. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Isn't "DISPLAY MAIN MENU" the default setting anyway?
    Until now I never knew how to NOT have the menu display first with TDA.
