Hi,
I have a video whose technical details is as follows:
Video Compression: Divx Codec (.avi)
Resolution: 624x272
Audio: 128Kbps (Lame MP3)
Total Video File Size: 700MB
Now I would like to make VCD so that I can view the movie (its a home video) in my standalone DVD player which unfortunately can not play DivX codec. I tried to use nero to write it as a VCD but the size is beyond the capacity of 1 disk. So how can I make a VCD out of it?![]()
Moreover I am not sure whethere the video is PAL or NTSC but my player supports PAL only. If the file is in NTSC can it be converted to PAL?
Please help![]()
Thank you
Closed Thread
If the framerate is 29.970 or 23.976 then it is NTSC. If the framerate is 25, it is PAL. VCD is limited to around 74 - 80 minutes per disc. What is the running time of your video ?
I am assuming you do not have a DVD burner, otherwise you would convert to DVD instead.Read my blog here.
Use gspot 2.52b to get the details you need. Post a screenshot of it's output here.
You will not fit it all on one VCD. You will have to find an appropriate place in the film to split the file ito two, then encode each seperately. The simplest tool to do this is probably virtualdubmod. You can load up the video, select the section you want, and save it out as a new video without re-encoding by using Direct Stream Copy mode. Repeat for the other other half. You can then use Nero on these seperate files to create your two VCDs.Read my blog here.
Thank you
Please find the screnshot enclosed.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator mats.hogberg
Sorry mate, can't help you any further. You need to read the forum rules again.
Read my blog here.
No help with illegal downloads here.
/Mats
New Receiver & DIVX
By denzlite in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2009, 05:35 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 07:02 -
Problem Divx's & Xvids
By ramses505 in forum Video ConversionReplies: 3Last Post: 8th Oct 2007, 09:39 -
ffdshow -XviD & DivX same?
By tigerb in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2007, 02:16
