    May 2006
    My audio is off and i'm guessing cause its the wrong bitrate, anyway to tell for sure it is and what would be the right bit rate
    off??? what are you doing? sync problems as in your other topic? then stay in that topic. no need to create a new topic.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I doubt it's the bitrate. Bitrate is just a quantative measure and does not affect the speed a twhich the audio is played or anything like that. That said, certain dvd players may have certain "preferences" as far as bitrate and or rate control method goes.
    GSpot your source and expand on the word "off" - https://forum.videohelp.com/viewtopic.php?t=271697 might assist.
    If in doubt, Google it.
