I just got a this player and am a bit bummed out by the playback quality of VCD's. My Apex 660a does a much better job.
I do video installations and want to be able to bring and use video in an easier format than VHS so I got this.
Here is me question:
Does anyone know is there is a better way to burn VCDs so this player will play a bit more smooth?
I remember someone saying something about a slightly different bitrate, but I don't know what it is or where that change would be made.
Would that be in the burning process or in the encodig process?
Thanks... anyone else have this player?
yeah. I got one. But I'm afraid I cant help you. When you say you want it smoother, do you mean that the picturemotion is somewhat uneven. 'Cause thats my problem too. I've tried some diffrent bitrates but I cant get it to work. The best "smoothnes" I've got is with Nero's own encoder. But then the sound out of sync. But is the smoothness the only problem you have ? what software do you use ?
The napa is problmatic, best way is to lower the bitrate to about 1120 and remove all the black borders. This is done at the encoding step
<font size=-1>[ This Message was edited by: Shabubu on 2002-01-06 15:05:12 ]</font> -
I haven't tested this yet, but it's fun too see that other people care. Atleast these settings work best on his napa.
http://www25.brinkster.com/fletchlinks/napa311/index.asp
MiniDV playback quality on different camcorder
By marksk918 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Dec 2011, 12:08 -
SD playback quality on LCD TV's
By Chris K in forum Newbie / General discussionsReplies: 20Last Post: 17th Nov 2010, 11:43 -
Awful DVD playback quality
By HamishM in forum Software PlayingReplies: 7Last Post: 11th Apr 2009, 11:16 -
Video Playback Quality
By sdculp in forum Authoring (DVD)Replies: 7Last Post: 21st Mar 2009, 17:08 -
Best Size/Quality for TV (PLasma/LCD) Playback?
By Rjupiter in forum DVD RippingReplies: 9Last Post: 26th Nov 2008, 22:18
