After working on a dvd that required pretty specific chapter markers and burning it to a dvd, the chapters are a few seconds off when I play it. I've tried it in two different dvd players and my pc, and get the same result every time. Is this common, or do I have something set wrong in DVD Architect?
I'm not familiar with DVD Architect, but hopefully my "general" advice may rule a few things out.
Any authoring software worth its salt should only allow you to set chapter markers on I frames. It is then the responsibility of yourself and your encoder to ensure that I frames occur exactly where you want the chapter stops to go.
So the first thing I would do is confirm that your chapter stops are on I frames. The GOP settings (length, and open or closed) you used whilst encoding may also provide some hints.
Purely for the purposes of confirming/denying that it is the software or the source (I understand that you're using DVD Architect for a good reason), how about DL-ing some other authoring software, setting a couple of chapter points in the same spots and see what the output does ? I'm only suggesting this because if the same behaviour occurs, then it's the source material. If it's fixed, then DVD Architect is causing the problem.
It should at least help you narrow down the problem.If in doubt, Google it. -
Originally Posted by canadateck
@jimmalenko:
I'm still pretty green at dvd authoring, so I'm not sure what you mean by I Frames and GOP settings. I'm going to search around on this site and google to get a little more info, but in the meantime, do you have any suggestions for other authoring programs I could try?
Thanks everyone for the replies.
*EDIT*
Ok, so I tried using DVD Lab to author the DVD and while importing the video, it told me that I had open GOP's and that can cause chapters to not start properly, so I guess that's the cause. I'll try re-encoding, hopefully that'll fix the problem.
VOB2MPG chapter split - inaccurate?
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 16th Dec 2010, 14:43 -
Adding Chapter Markers
By Big Jake in forum Authoring (DVD)Replies: 11Last Post: 11th Sep 2010, 23:50 -
Sony DVD-Architect won't load markers in mpeg file rendered in Vegas
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 10:01 -
AVI to DVD with chapter markers?
By cleantone in forum ffmpegX general discussionReplies: 1Last Post: 18th Oct 2007, 03:26 -
Toast 7 - Chapter Markers from iMovie
By Surfmaster in forum MacReplies: 14Last Post: 3rd Jul 2007, 13:43
