Hello, I am trying to burn a DVD but when I put in my brand new, just out of the wrapper DVD disc, it keeps telling me the media is not blank and asking me to erase the contents. I click yes, and then it asks me again, and it keeps asking. I've tried with 2 brand new DVD's that were sealed and got the same problem. I am using Philips DVD+RW 120 min Video 4.7 GB data DVD's. What could be wrong?
What happens if you just put the disk in your drive, click on "My Computer", then right click the drive, and then click on "Properties"? Will your computer recognize these disks?
It brings up the properties menu, it says:
Type: CD Drive
File System: RAW
Used Space: 0 bytes 0 bytes
Free Space 0 bytes 0 bytes
Capacity: 0 bytes 0 bytes
Drive E -
1. Do your have a DVD burner in your PC ?
2. What's the Make & Model of your DVD burner ?
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
It came with my Dell PC.... TSSTcorp CD/DVDW TS-H552B is the name of it under Properties.
Ok,
It's a Toshiba TS-H552B. Seems like lots of users have reported severe problems with this piece of hardware. You can see full reports here:
https://www.videohelp.com/dvdwriters.php?DVDname=h552b&Submit=Search&cdrs=&cdrws=&dvdrs...&Search=Search
One user says it always fails with DVD-Rw but is OK with DVD-R, so maybe try that. don't burn any faster than 4X either.
If you really want to get into DVD burning - I suggest you buy a new DVD burner - Pionerr is a good buy !!
Good luck.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
