Hello. I recorded a cartoon from tv onto my camcorder, I then edited all the commercials out with Adobe Premiere and encoded it as a MPEG-DVD, which created a .m2v file and a .wav file. The 20 minute cartoon is now a total of 700 megs, the non audio m2v file is 500 and the .wav is 200 megs.
I then added the m2v file to Nero Vision and I am trying to burn it. Its going really slow while it is 'transcoding'. I thought encoding it as a MPEG-DVD in Premiere would prevent me from waiting for it to transcode when I burn it?
Also, is it normal for a 20 minute cartoon to be 700 megs? Is there a way to make it smaller without hurting the quality so I can put alot of cartoons on one DVD movie
If it is DVD compliant, it shouldn't need to be re-encoded. See 'What is' DVD to the upper left for the DVD specs. You can reduce the audio size considerably and make it more DVD compliant by using a program like ffmpeggui to convert the audio to AC3. If the video and audio are DVD compliant, you just need to author it, not re-encode it. You might try a different program like TMPGEnc DVD Author or the freeware DVDAuthorgui for that.
The size of the MPEG-2 file depends on the bitrate used. You can use a bitrate calculator to see the bitrate needed to get the size of MPEG-2 you want. There are several bitrate calculators in 'Tools' to the left. As far as quality, you are the only judge of that. Try a sample clip of 5 minutes at different bitrates and see how it looks. Cartoons should be able to tolerate a fairly low bitrate without much quality loss. -
What version of NeroVision are you using?Make sure you enable SmartEncoding in video options.
I would reduce the video bitrate and use the AC3 plugin($20USD) to make the output smaller. -
Use something else for dvd authoring like tda. Nero Vision may be a good all-in-one solution but not for already prepared dvd mpgs.
And this is not any dvd to dvdr backuping. Moving you.
Convert MKV to DVD video for burning with Nero Vision
By OreRockOn in forum Video ConversionReplies: 3Last Post: 4th Jan 2010, 11:42 -
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 12:36 -
Nero Vision - preview screen when burning
By bigj7489 in forum Authoring (DVD)Replies: 0Last Post: 15th May 2008, 13:57 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 01:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
