Hi,
I have mpeg2 files endoded with my hauppauge PVR150 and i would like to be able to transform all this quickly and easily to a dvd format (VOB with IFO and BUP).
Now i use 1 prog to cut the peace i need (remove the publicy from the file...), 1 prog to demux the mpeg file and ifoedit to remux, put chapter and put all this in VOB format with ifo and bup.
It's slow and needs 3 programms (freeware) like this but it works.
Do you have any programms that can do all this quickly? freeware and not too big if possible
thx in advance
TMPGEnc DVD Author ! but it isn't free though. I haven't seen any free tool that supports both editing and dvd authoring.
and mpeg2 to vob is authoring. moving you. -
ok thx
if somebody know something better or free and still good, i take
The hauppauge series should come with a version ulead dvd moviestudio. Assuming it was bought new it should be included in your software bundle. It will take your dvd compatible mpeg 2 file and let you author a menu and create the folders and burn the disc. (if not ulead then roxio)
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thx true yodaOriginally Posted by yoda313
i will look after my hauppauge cds. if ulead is not too big and doesn't take too much time too make the work, it's ok.
DVD to VOB/MPeg2
By Westport in forum MacReplies: 6Last Post: 9th Oct 2011, 21:41 -
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 10:19 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 18th Dec 2008, 00:37 -
Vob / Mpeg2 editing with Vdub
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2008, 18:55 -
VOB to MPEG2(lossless)
By santosh86 in forum DVD RippingReplies: 1Last Post: 6th May 2007, 15:29
