Is it possible without having to recompress ?
virtualdubmod - append video - save out with Direct Stream Copy
Can't guarantee sync, but worth a try.Read my blog here.
I used MergeMP3, but had to use mp3DirectCut to rewrite the header of the new mp3 file (it was written as a CBR)
But it didn't work very well, the audio in the second part got out of sync. -
I did find a solution for sync such problematic MPR-VBR audio, some of AVI files gets out of sync despite of extracting to wav and recompress, or just uncompress
What you must do is pass each AVI file separately in AVIMUX-GUI tool and then join the resulting files together, must be this way...i.e. (separately "mux" each file and join the resulting files)
The resulted joined AVI than can be processed in VDUB without problems of sync, its safe, but I recommend uncompressed it
and it works
Join/Merge several mp3 into a new one
By elmuz in forum AudioReplies: 0Last Post: 21st Jul 2010, 04:02 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 07:21 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 25th Aug 2008, 23:59 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 19:19 -
Avi.Net VBR MP3
By KnightHeart in forum Video ConversionReplies: 0Last Post: 8th Jul 2007, 06:40
