  1. Once you burn a VCD. is there a way to play it on the computer? or even the BIn files that are used to make the CD. Is there a way to convert them back to video files?(if they are video files.)
    Just wondering cuz i cant play VCD on my DVD playerd at home!
    CAN I HAVE YOUR COOKIES?
    Yes, you can play VCDs on your computer, https://www.videohelp.com/play#vcd
    and I think you can play the bin directly with VLC or extract the video from the bin with isobuster or mount the bin as a virtual cd unit with daemon tools.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Isobuster can extract the just the video files you need. Or you can mount the bin/cue with daemontools to play it as a VCD on your PC.
    Read my blog here.
  4. cool thankyou guyz!
    Feb 2004
    Australia
    Vcdgear to extract mpeg from dat .
    Koolplaya should beable to play vcd .
    www.downloads.com , cd/dvd emulation , there are 3 free one's available ... the sheep is fine .
    As for converting to dvd , try super (output as mpeg2 / ac3)
    Demux using batchdemux
    Author with dvdauthorgui
    Burn with nero .. and enjoy .
