Results 1 to 10 of 10
Describe what happens when you get this error.
Post your log.
Use Gspot to check the details of your AVI and post those results also.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thanks for the reply, I've attached the error thats shown. Basically it comes up with the windows system error box which states ffmpeg encounted problems and needs to close, I've tried different avi's all with the same problem ?? if i just put an mpeg2 file in their it makes a dvd no problem, so i take it, it is when its trying to split the avi.
Understood, but we need to know how far into the process this happens, we need to see the log file and the information from Gspot can be a help in finding out if it's the AVI that ffmpeg has a problem with or if it's something else.
Have you successfully converted AVI files on your system with any other tools? Are you using the latest build of SVCD2DVD?
Giving us this information will help us to help you, without there's not much we can do.Dwight
- Herm Albright
Thanks I put the file thro g spot and renderered it no problem correct codecs installed etc, I've used tmpeg author to do the files no problem, so I'm thinking its conflicting somewhere, i've also tried the latest version of svcd2dvd and this gives the same problem. I've used this tool basically from when it first came out and this is the first time i've had issues with it.
- Herm Albright
Here you go mate.
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="29/05/2006 10:38:04" Filename="NONE"><AssetSet><Asset ID="9075b22e-dc12-4b79-93c7-5148afc1af3e" Path="D:\DVD FILES\24" Filename="24.s05e21.720p.hdtv.ac3.5.1.xvid-hv.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="24.s05e21.720p.hdtv.ac3.5.1.xvid-hv.avi" AssetID="9075b22e-dc12-4b79-93c7-5148afc1af3e" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="H:\MUSIC\Mission_Impossible_3 OST\03 - Evacuation.mp3" /></DVDStructure><Settings><General InitialAssetFolder="D:\DVD FILES\SVCD2DVD TEMP" InitialDVDFolder="D:\DVD FILES\SVCD2DVD TEMP" InitialProjectFolder="D:\DVD FILES\SVCD2DVD TEMP" InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="H:\MUSIC\Mission_Impossibl e_3 OST\03 - Evacuation.mp3" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="True" /><Process AudioEncoding="ac3" Chapters="Every 0 mins (none)" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="False" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="DVD Decrypter" DVDDrive="_NEC DVD_RW ND-4571A " NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="C:\Program Files\DVD Decrypter\dvddecrypter.exe" DVDDErase="False" DVDDClose="False" DVDDDontBurn="True" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 1.36 GB
file=D:\DVD FILES\24\24.s05e21.720p.hdtv.ac3.5.1.xvid-hv.avi
FormatName=avi
Num_Frames=61171
DurationInSecs=2551
Duration=00:42:31.0
VideoCodec=mpeg4
Width=1280
Height=720
Standard=NTSC (Film)
BitRate=4605
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio1Channels=6
AVI2MPG: 7800kbs Full-D1
10:38:04: Looking for AVI PAR...
Leaving source audio alone.
Pass 1/1: Processing 24.s05e21.720p.hdtv.ac3.5.1.xvid-hv.avi
10:38:05: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
10:38:05: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
10:38:05: libavutil version: 49.0.0
10:38:05: libavcodec version: 51.4.0
10:38:05: libavformat version: 50.2.1
10:38:05: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
10:38:05: Input #0, avi, from 'D:\DVD FILES\24\24.s05e21.720p.hdtv.ac3.5.1.xvid-hv.avi':
10:38:05: Duration: 00:42:31.0, start: 0.000000, bitrate: 4605 kb/s
10:38:05: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 1280x720
10:38:05: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
10:38:05: Output #0, dvd, to 'D:\DVD FILES\24\24.s05e21.720p.hdtv.ac3.5.1.xvid-hv_S2D.mpg':
10:38:05: Stream #0.0, 29.97 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 7800 kb/s
10:38:05: Stream mapping:
10:38:05: Stream #0.0 -> #0.0
10:38:05: Stream #0.1 -> #0.1
12:07:49: AVI2MPG: done.
12:07:49: Done: Processing assets for DVD creation
Authoring DVD Folders
12:07:49: Creating TitleSet # 1 -
You cut off the top of your log with system information, but I can see that your source and destination drives are both "D". Is it possible that you are running out of hard drive space during authoring?Dwight
- Herm Albright
Thanks for the response, I've plenty of hard drive space and the reason it goes to the next stage after ffmpeg is because it comes up with an errorand says it will have to close ( windows error box ), but I've just tried it again after readin a post from way back in regards of the system overheating, so I had a look at the system and cpu temp ( the cpu was 75 * c ??? ) I've fixed a fan and the temp is now 62 * c. I've re encoded the file that was first giving the issues and it's sailed thro no problem ?? is it all down to overheating and is the svcd2dvd sapping my resources is this why came up with the errors ???
But thanks once again -
Sounds like overheating, but that is usually just a crash, glad you got it working.
What kind of processor are you running? Mine is a slightly overclocked AMD 2600XP and rarely breaks 45C under load.
As to S2D "sapping resources", video encoding is very CPU intensive. If you think ffmpeg is a drain, try CCE sometime (100% CPU all the time).Dwight
- Herm Albright
Error in Virtualdub while converting mkv to avi
By anchonio in forum Video ConversionReplies: 6Last Post: 1st Aug 2011, 02:36 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Error when converting to avi
By Fashionita in forum ffmpegX general discussionReplies: 4Last Post: 21st Nov 2008, 10:22 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41
