Hi,
Is it possable to input data from a dvd Recorder into a DVin on a cam, or
is the input only IN and not OUT on a dvd recorder.
I know the older Pioneer models could do DV in and out. Not sure if newer Pioneer's still have this option, but I *think* so.
Confirmed, my Pioneer hard-drive/DVD recorder does firewire in & out, except whenOriginally Posted by piano632
playing copy protected DVD discs.
But more interestingly, exactly why do you want to export video to your DV camcorder?
If you'd care to share with us, describe the nature of the project you are attempting to
accomplish. -
I just got a panasonic GS500 as a replacement for me GS400 that stop working, but the 500 dose
not have AV ins, i wish to run my panasonic M5 & M10 VHS tapes in the dvd recorder and input
into my Gs500 dv port! so i can edit my tapes, my Panasonic E55 dose not have firewire so
i wish to buy a new one that dose.
If I understand correctly, your basic question is "How to digitize VHS tapes for editing"?Originally Posted by nwo
If your VCR has composit outputs (yellow RCA jack), why not just plug directly into
the DVD recoder's inputs, only capture the scenes that you want, then take that disc
and edit the scenes with an MPEG cutter in your computer?
Is there such a thing as a DVD Recorder with HDMI Input?
By the_importer in forum DVD RippingReplies: 10Last Post: 11th Aug 2013, 04:30 -
Im looking to buy DVD Recorder with HDD and a RGB Input
By marionr26 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2010, 20:45 -
Getting the dvd recorder input incorporated into the mix for recording
By duckman in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2010, 00:41 -
DVD Recorder With HDMI Input
By wulf109 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Nov 2008, 15:12 -
DVD Recorder that accepts HDMI or Component input
By AuditSup in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Aug 2007, 02:39
