Hello everybody![]()
I've been using TMPgenc 2.5 Plus to encode video files to mpeg with no problems 8)
Recently i got the TMPGenc 3.0 Xpress but it cannot open .avi files that come with the XviD Codec
i got the latest codec but it still gives the error message that cannot open the file.![]()
Is there any solution to this problem?
Because you need to install the XVID codec and raise DirectShow in the TMPGEnc Plus 2.5 environmental settings. Not too sure about 3.0, as that software IS NOT AN UPGRADE but rather a different type of software.
TMPGEnc problem? Click here.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thank you guys for replying
I did installed the latest XviD from Koepi's web page
but still doesnt want to open the file.
I also cheked the post Zippy but it only tells u need to install the codec
but thanks anyway
hmmp, Xpress like more DivX than XviD. grrr
Do i have to modify some settings on TMPGenC Xpress?
lordsmurf u also told me abaut raising DirectShow, does direcshow may be cousing problems on TMPGeC Xpress? -
Do yourself a favour and go back to using Plus 2.5. As lordsmurf said, XPress isn't the same program as Plus 2.5 was. 2.5 is a piece of soft for people who know a bit about what they want to do. XPress is designed for the newbie user and has too many restrictions.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 10:54 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 14:01 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
