I have downloaded these files and in the properties of these files they are mpeg4. im wondering how I can author these files into a DVD because my authoring programs wont reconize them.
Results 1 to 12 of 12
Well, you have to convert it to DVD specs mpg2 first. Take a look under CONVERT left.
/Mats -
Not sure, since I don't do DVD conversions of downloads (I got me a AVI capable player, for those rare occurances when what I want to view on the TV that isn't available on DVD). If AVI2DVD swallows your source file - fine. DivX2DVD (or the later version convertx2dvd) is another application for "convert to DVD" getting much acclaim lately.
/Mats -
Source as in "the file you're trying to make DVD from".
/Mats -
Gspot will let you know if you have the correct decoder's installed ... without these , conversion is not possible .
Avi2dvd dose a pretty good job and is reasonable , allowing some user input ... and a menu if you want to go the whole way .
Super ... mpeg2 out is fine ... vob output is another thing ... I use it to fix problematic avi's .
If ifoedit wont touch a particular mpeg2 encoded video stream during authoring , I wont use it . -
OK well I used Nero to convert my Mpeg4 files to a dvd format, but the outcome is a very very choppy video. The picture and sound look great but it isnt smooth at all. What can I do to fix the problem?
Don't use Nero. It's among the worst apps you can use for conversions.
/Mats -
As far as Ive read, these mp4's im trying to convert are Itune videos. Does anybody know a conversion program that will work for this? Also if someone can recommend a good screen capping program that maybe I can convert it that was. Also the program needs to be free, wihtout watermarks and able to convert at least 2 hours of video.
Cheers!
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
