I've just started using this software and burned my first disc with no drama. The second one I tried ended up on the disc with no sound. It was a single file with a simple main menu and the file needed the XVid codec to be read by the program.
It got to the stage of burning when the project exceeded the capacity of the disc by a very small amount, but the program seemed to sort this out by itself. It said it would have to compress it and around 18 hours(!!!!) later the burning came out as a success. So I put the DVD in my separate player - no sound, I tested it on my brother's - no sound, then I tried it on the PC - no sound!
The first project was a complete success, so why did this happen? I'm confused![]()
Show me a bored kid, I'll show you a lazy kid
what is the source file details? video and audio codec, identify with avi2clipboard.
best for xvid sources is convertxtodvd / divxtodvd. -
Total size (Bytes): 733,087,524Originally Posted by Baldrick
Total size (KB): 715,906
Total size (MB): 699.13
Total streams: 2
Video size (Bytes): 649,917,512
Video size (KB): 634,685
Video size (MB): 619.81
Video length: 01:26:38
Video codec code: XVID
Video codec name: XviD MPEG-4 codec
Video bitrate: 1000 KB/s
Resolution: 608x336
Aspect ratio: 1:80:1
Total frames: 155781
Frame rate: 29.97FPS
Colour depth: 24 bits
Quality factor: 0.163 B/px
Packed bitstream: No
Audio size (Bytes): 83,168,000
Audio size (KB): 81,219
Audio size (MB): 79.32
Audio length: 1:26:38
Audio codec code: 85 (0x0055)
Audio codec name: MPEG-1 layer 3 (MP3)
Audio bitrate: 128 KB/s (CBR)
Channels: 2
Sampling rate: 48000Hz
Just to add the source file for the successful DVD is an mpg, which I thought might be useful info.Show me a bored kid, I'll show you a lazy kid -
If MovieFactory told you the project was too large I wouldn't count on the final DVD working properly. You should go to the Project Settings dialog and change the bitrate ("Change MPEG Settings") to make the project fit. Also, when working with AVI files, turn off the "Do not convert compliant MPEG files" option. Otherwise the program will not recalculate the size on the timeline bar at the bottom of the window.
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 15:54 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 06:14 -
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 17:48 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43
