I have just started making dvds. I have been filming and distributing vhs. I noted that not all dvds play on all dvd players. How do I select the most universal dvd on which to record so that my customers will not have problems?
Have a look at this:
http://www.digitalfaq.com/media/dvdmedia.htm
Use first-class media. DVD-R has a slight compatibility edge on older players, although if you bitset +R discs, the difference is probably negligible or non-existent. Good luck.
Pull! Bang! Darn! -
I have a few older DVD players that will only play DVD-R X4. And some brands of DVD-Rx4s will not play at all. None the less, X4 is the way to go.
You need to buy these online. -
Thanks for the responses. I consulted with the folks at the local community access television station. They have converted to DVD over the past few months and did a lot of research. They had noted that several other stations got lots of returns on DVDs that would not play. Here is what they found:
1. Using an external DVD recorder to "make movies" rather than the DVD recorder in the computer is effective.
2. They use DVD-Rs purchased online--One of the brands listed as best on the site that you recommended I study.
3. So far, they have had no returns.
My further question is: should I use an external DVD recorder? Have you had this suggestion made before?
And one other question: I have not been able to get a mike to work for voice overs. The folks at the television station told me that they have never had great luck with miked voiceovers recorded directly onto the software and that they record voiceovers on a separate medium and then load them onto the voiceover track. Does this sound familiar?
Thanks.
need help selecting the right tool
By willymakit100 in forum Authoring (DVD)Replies: 3Last Post: 6th Jul 2011, 12:03 -
Help selecting new camcorder
By shredman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Apr 2010, 14:28 -
Selecting the preferred DVD decoder/codec for WMP under Vista x64
By Dark Alpha in forum Software PlayingReplies: 10Last Post: 17th Jan 2009, 22:05 -
help in selecting chapt of different versions on DVD to rip
By willcarson in forum MacReplies: 2Last Post: 16th Jan 2008, 10:05 -
Need serious HELP on selecting MUSIC
By jimcornetet in forum Newbie / General discussionsReplies: 5Last Post: 15th Jun 2007, 21:52
