I have been trying to determine how best to 'down convert' a couple HD-Divx family vids my brother sent me. (Boy, is HE gadget prone.)
Unfortunately, I haven't come across any specific software tool to do this (yet, still looking, experimenting).
Has anyone tried to do this? Any success with existing tool(s)?
THanks.
I've tried a simple approach - passing these files through DIVX Converter. Seems to work, but halfway through the output file, the audio is barely there. (Even left a message to the DIVX developers, but haven't heard from anyone yet.)
Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
You could always ask your brother for a DV or DVD MPeg2 version. His camcorder probably has hardware downscaling to DV.
http://www.kiva.org/about -
what tools have you tried? most encoders should have NO problems with hddivx.
what is the audio format? -
Well, the original file was clearly unplyable on my Phillips 642.
It gave me a message that the resolution was incompatible.
I passed it through the Divx Converter with the 6.2 codec thinking it would suffice.
It lowered the resolution to 720x416.
The audio appears to be AC3.
(160kbps, 44khz, 2 ch, mpeg-1 layer 3)
I'm thinking of trying Convertx2dvd, but hadn't got around to it yet.
This week has been rather trying as two of my other PCs motherboards bit the dust leaving me withmy slowest P4.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
The audio is mp3. I can't see why virtualdub wouldn't handle this type of video, then frameserve it to an encoder.
Read my blog here.
Either use the drop down list under Open in VirtualDub and choose All Files to get the file to show up or change the extension to .avi
Choose the resize filter to make the resolution the size you want and recode the video to XviD and direct stream copy the audio which is MP3.
I bought the Philips DVP5140 today at Walmart but I haven't tested any off the wall encodings yet to see how they play.
I didn't have any problems with the 642 since all my encodes were up to specs although there was a file I downloaded that wouldn't play. GMC or Qpel, I'm not sure.
Downloaded the Madagascar HD trailer and it looks great on the 19" PC monitor. Curious to see how it looks through the 5140.
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
DVD to Divx/XviD for a 40" HDTV. What resolution?
By marioval in forum DVD RippingReplies: 14Last Post: 8th Nov 2010, 13:13 -
Can philips dvp 3588 dvd player,play a divx file of 720p resolution?
By jazzymegatron in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Jul 2010, 11:06 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
DVD to Xvid/Divx what resolution to use?
By David9799 in forum DVD RippingReplies: 10Last Post: 7th Nov 2007, 15:16
