Results 1 to 14 of 14
  1. I install the LAME Codec but it does not show up in my VirtualDubMod.. is there a way to get it to show up?
    CAN I HAVE YOUR COOKIES?
    Nov 2002
    Are you sure it's installed?
    Right click on LameACM.inf and then click Install
    You have to restart Virtualdub if you already have it open or it won't show up.
    If that doesn't help, you might try this fix.
    http://forum.doom9.org/showthread.php?s=&threadid=24305
  3. no i installed it like 4 times and still not showing. im gonna try that other thing there! THANX
    Nov 2002
    Good luck. I've never had this problem since it seems to be an XP thing. Hope it fixes your problem.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Lame works in Virtualdub(mpeg) on my XP Pro SP2 machine....it also shows up in Windows Soundrecorder (sndrec32.exe)...you might want to check there too to see if it is installing at all on your system.
  6. negative, i dont know how to get to where its telling me to go.
    1. Search the followind Key in the registry:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
    HOW do i search the registry?
    Nov 2002
    The post explains the process but if you're not comfortable or experienced with the registry then according to the thread, this program is suppoesed to fix the registry key.
    http://www.btinternet.com/~digital56k/BigFix1.6b.exe
    Just download and run. You might run a virus scan on the file just in case. I like to do that to every file I download before install.
  8. ThanX man
  9. He we go. I hope i did it right.
    heres the Log file
    BigFix log file
    BigFix version 1.6b
    * Disable XP AVI Properties Handler
    | Removing registry key
    | Success
    * Enable XP AVI Properties Handler
    | Writing registry key
    | Success
    * Remove G400 filter
    | Attempting to unregister G400 filter
    | Checking for file (C:\WINDOWS\system32\divxg400.ax)
    | File not found
    * Remove Bicubic Resize filter
    | Attempting to unregister Bicubic Resize filter
    | Checking for file (C:\WINDOWS\system32\bicubic_resizer.ax)
    | File not found
    * Remove DivX Anti-freeze filter
    | Attempting to unregister DivX Anti-freeze filter
    | Checking for file (C:\WINDOWS\system32\divXaf.ax)
    | File not found
    * Remove XviD filter
    | Attempting to unregister XviD filter
    | Checking for file (C:\WINDOWS\system32\xvid.ax)
    | File found
    | Unregistering XviD filter...
    | Success
    * Set FFDShow does not handle DivX
    | Setting option for FourCC DIV3
    | Setting option for FourCC DIVX
    | Setting option for FourCC DX50
    * Remove FFDShow decoder
    | Checking for installation path in registry
    | Success (C:\Program Files\ffdshow)
    | Attempting to unregister FFDShow decoder
    | Checking for file (C:\Program Files\ffdshow\ffdshow.ax)
    | File found
    | Unregistering FFDShow decoder...
    | Success
    * Check FFDShow is installed
    | FFDShow filter found (C:\Program Files\ffdshow\ffdshow.ax)
    * Set 3ivX does not handle DivX
    | Reading 3ivX settings from registry
    | Failed (3ivX may not be configured)
    * Remove 3ivX decoder
    | Attempting to locate 3ivX installation
    | 3ivX does not appear to be installed
    * Fix 'Downgrading from 5.1' Protexis issue
    | Removing Protexis registry key
    * Set full-sized DV Decoding
    | Checking DirectX version
    | DirectX version is ok (4.09.00.0904)
    | Setting DV Decoder filter properties
    * Fix 'Registration does not complete' issue
    | Checking for KGyGaAvL.sys
    | File not found
    * Fix Cyberlink (PowerDVD) incompatibility (Unexpected stop during encoding pass)
    | Launching Cyberlink download site
    * Check AC3Filter version
    | AC3Filter version is at least 0.7
    * Set compatible AC3Filter options
    | Setting mode to 2-channel Stereo
    | Setting format to 16-bit
    | Setting no SPDIF output
    | Setting auto-gain on
    | Setting normalize on
    | Setting Master volume = 4.5
    | Setting dynamic range control on
    | Setting dynamic range power = 1.0
    * Remove Morgan Stream Switcher filter
    | Attempting to unregister Morgan Stream Switcher filter
    | Checking for file (C:\WINDOWS\system32\mmswitch.ax)
    | File found
    | Unregistering Morgan Stream Switcher filter...
    | Success
    * Remove SubTitDS filter
    | Attempting to unregister SubTitDS filter
    | Checking for file (C:\WINDOWS\system32\SUBTITDS.AX)
    | File not found
    * Remove DirectVobSub filter
    | Attempting to unregister DirectVobSub filter
    | Checking for file (C:\WINDOWS\system32\dvobsub.ax)
    | File not found
    * Remove Darim Vision MPEG2 filter
    | Attempting to unregister Darim Vision MPEG2 filter
    | Checking for file (C:\WINDOWS\system32\mp2filt.ax)
    | File not found
    * Remove Elecard MPEG2 Decoder filter
    | Attempting to unregister Elecard MPEG2 Decoder filter
    | Checking for file (C:\WINDOWS\system32\mpgdec.ax)
    | File found
    | Unregistering Elecard MPEG2 Decoder filter...
    | Success
    * Remove Elecard MPEG2 Demux filter
    | Attempting to unregister Elecard MPEG2 Demux filter
    | Checking for file (C:\WINDOWS\system32\mpeg2dmx.ax)
    | File found
    | Unregistering Elecard MPEG2 Demux filter...
    | Success
    * Remove Etymonix MPEG2 codec
    | Attempting to unregister Etymonix MPEG2 codec
    | Checking for file (C:\WINDOWS\system32\EtxCodec.dll)
    | File not found
    * Remove Fraunhoffer MPEG2 Audio filter
    | Attempting to unregister Fraunhoffer MPEG2 Audio filter
    | Checking for file (C:\WINDOWS\system32\dvdaudio.ax)
    | File not found
    * Remove Fraunhoffer MPEG2 Video filter
    | Attempting to unregister Fraunhoffer MPEG2 Video filter
    | Checking for file (C:\WINDOWS\system32\dvdvideo.ax)
    | File not found
    * Remove I-Media Mutliple MPEG2 Source filter
    | Attempting to unregister I-Media Mutliple MPEG2 Source
    | Checking for file (C:\WINDOWS\system32\multiple_mpeg2_source.ax)
    | File not found
    * Remove InstantCopy VOB-MPEG2 filter
    | Attempting to unregister InstantCopy VOB-MPEG2 filter
    | Checking for file (C:\Program Files\Pinnacle\InstantCD+DVD\SharedFiles\vobmpg2.a x)
    | File not found
    * Remove Ligos MPEG2 Parser filter
    | Attempting to unregister Ligos MPEG2 Parser filter
    | Checking for file (C:\WINDOWS\system32\mpeg2parser.ax)
    | File found
    | Unregistering Ligos MPEG2 Parser filter...
    | Failed
    * Remove Ligos MPEG2 Decoder filter
    | Attempting to unregister Ligos MPEG2 Decoder filter
    | Checking for file (C:\WINDOWS\system32\mpeg2decoder.ax)
    | File not found
    * Remove Ligos MPEG Splitter filter
    | Attempting to unregister Ligos MPEG Splitter
    | Checking for file (C:\WINDOWS\system32\lmpgspl.ax)
    | File not found
    * Remove Mediamatics MPEG2 Splitter
    | Attempting to unregister Mediamatics MPEG2 Splitter
    | Checking for file (C:\WINDOWS\system32\MMSPLIT.DLL)
    | File not found
    * Remove NanoCosmos MPEG2 filter
    | Attempting to unregister NanoCosmos MPEG2 filter
    | Checking for file (C:\WINDOWS\system32\m2v_dec.ax)
    | File not found
    * Remove Adaptec DV codec
    | Attempting to unregister Adaptec DV codec
    | Checking for file (C:\WINDOWS\system32\dvcodec.dll)
    | File not found
    * Remove Canopus DV codec
    | Attempting to unregister Canopus DV codec
    | Checking for file (C:\WINDOWS\system32\cdvccodc.dll)
    | File not found
    * Remove MainConcept DV codec
    | Attempting to unregister MainConcept DV codec
    | Checking for file (C:\WINDOWS\system32\mcdvd_32.dll)
    | File found
    | Unregistering MainConcept DV codec...
    | Failed
    * Remove Panasonic DV codec
    | Attempting to unregister Panasonic DV codec
    | Checking for file (C:\WINDOWS\system32\pdvcodec.dll)
    | File not found
    * Remove Pinnacle DV25 codec
    | Attempting to unregister Pinnacle DV25 codec
    | Checking for file (C:\WINDOWS\system32\digivcap.dll)
    | File not found
    * Registry: Remove any invalid drivers
    | Checking drivers
    | Checking midimapper
    | Entry is ok
    | Checking msacm.imaadpcm
    | Entry is ok
    | Checking msacm.msadpcm
    | Entry is ok
    | Checking msacm.msg711
    | Entry is ok
    | Checking msacm.msgsm610
    | Entry is ok
    | Checking msacm.trspch
    | Entry is ok
    | Checking vidc.cvid
    | Entry is ok
    | Checking vidc.I420
    | Entry is ok
    | Checking vidc.iv31
    | Entry is ok
    | Checking vidc.iv32
    | Entry is ok
    | Checking vidc.iv41
    | Entry is ok
    | Checking vidc.iyuv
    | Entry is ok
    | Checking vidc.mrle
    | Entry is ok
    | Checking vidc.msvc
    | Entry is ok
    | Checking vidc.uyvy
    | Entry is ok
    | Checking vidc.yuy2
    | Entry is ok
    | Checking vidc.yvu9
    | Entry is ok
    | Checking vidc.yvyu
    | Entry is ok
    | Checking wavemapper
    | Entry is ok
    | Checking msacm.msg723
    | Entry is ok
    | Checking vidc.M263
    | Entry is ok
    | Checking vidc.M261
    | Entry is ok
    | Checking msacm.msaudio1
    | Entry is ok
    | Checking msacm.sl_anet
    | Entry is ok
    | Checking msacm.iac2
    | Entry is ok
    | Checking vidc.iv50
    | Entry is ok
    | Checking msacm.l3acm
    | Entry is ok
    | Checking wave
    | Entry is ok
    | Checking midi
    | Entry is ok
    | Checking mixer
    | Entry is ok
    | Checking vidc.VP60
    | Entry is ok
    | Checking vidc.VP61
    | Entry is ok
    | Checking vidc.XVID
    | Entry is ok
    | Checking vidc.ffds
    | Entry is ok
    | Checking vidc.yv12
    | Entry is ok
    | Checking vidc.X264
    | Entry is ok
    | Checking vidc.wmv3
    | Entry is ok
    | Checking vidc.vp62
    | Entry is ok
    | Checking vidc.hfyu
    | Entry is ok
    | Checking msacm.ac3acm
    | Entry is ok
    | Checking msacm.at3
    | Entry is ok
    | Checking msacm.divxa32
    | Entry is ok
    | Checking msacm.lameacm
    | Entry is ok
    | Checking msacm.l3codec
    | Entry is ok
    | Checking msacm.voxacm160
    | Entry is ok
    | Checking msacm.scg726
    | Entry is ok
    | Checking msacm.alf2cd
    | Entry is ok
    | Checking vidc.dvsd
    | Entry is ok
    | Checking vidc.mpg4
    | Entry is ok
    | Checking vidc.mp42
    | Entry is ok
    | Checking vidc.mp43
    | Entry is ok
    | Checking vidc.DIVX
    | Entry is ok
    | Checking msacm.mpegacm
    | File does not exist (mpegacm.acm)
    | Removing 'msacm.mpegacm'='mpegacm.acm' - invalid entry
    | Checking msacm.ulmp3acm
    | File does not exist (ulmp3acm.acm)
    | Removing 'msacm.ulmp3acm'='ulmp3acm.acm' - invalid entry
    | Checking msacm.dvacm
    | Entry is ok
    | Checking msacm.avis
    | Entry is ok
    * Registry: Remove invalid video compressors only
    | Checking video compressors
    | Checking vidc.cvid
    | Entry is ok
    | Checking vidc.I420
    | Entry is ok
    | Checking vidc.iv31
    | Entry is ok
    | Checking vidc.iv32
    | Entry is ok
    | Checking vidc.iv41
    | Entry is ok
    | Checking vidc.iyuv
    | Entry is ok
    | Checking vidc.mrle
    | Entry is ok
    | Checking vidc.msvc
    | Entry is ok
    | Checking vidc.uyvy
    | Entry is ok
    | Checking vidc.yuy2
    | Entry is ok
    | Checking vidc.yvu9
    | Entry is ok
    | Checking vidc.yvyu
    | Entry is ok
    | Checking vidc.M263
    | Entry is ok
    | Checking vidc.M261
    | Entry is ok
    | Checking vidc.iv50
    | Entry is ok
    | Checking vidc.VP60
    | Entry is ok
    | Checking vidc.VP61
    | Entry is ok
    | Checking vidc.XVID
    | Entry is ok
    | Checking vidc.ffds
    | Entry is ok
    | Checking vidc.yv12
    | Entry is ok
    | Checking vidc.X264
    | Entry is ok
    | Checking vidc.wmv3
    | Entry is ok
    | Checking vidc.vp62
    | Entry is ok
    | Checking vidc.hfyu
    | Entry is ok
    | Checking vidc.dvsd
    | Entry is ok
    | Checking vidc.mpg4
    | Entry is ok
    | Checking vidc.mp42
    | Entry is ok
    | Checking vidc.mp43
    | Entry is ok
    | Checking vidc.DIVX
    | Entry is ok
    * Registry: Remove invalid ACM audio codecs only
    | Checking ACM audio codecs
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Checking msacm.iac2
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Checking msacm.at3
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Entry is ok
    | Checking msacm.avis
    | Entry is ok
    * INI files: Remove any invalid drivers
    | Checking drivers
    * INI files: Remove invalid video compressors only
    * INI files: Remove invalid ACM audio codecs only
    * Checking DivX version
    | DivX version is at least 5.0.5
    * Checking DirectX version
  10. The LAME Codec is still not coming up.
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Does it show up in your programs?
    You know....the place in XP where you go to delete programs "the correct way".
    I recently noticed the lame codec in there as being able to uninstall.
  12. It Does show up on my Programs List, it just isn't showing up in my V-dub!
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I don't know what to tell you man. I'm relatively computer stupid compared to most people and Lame shows up in both VirtualDub and Soundrecorder on my computer.
    As a matter of fact I just had to re-install it because I'm having keyboard problems and I set my computer configs back one month to see if something I installed in the meantime caused the problem...now lame is back and available in both Soundrecorder and Virtualdub.
  14. figures just my luck.
