  1. I have used decrypter on my home pc, now i am on the road with new laptop, and it says the dvd is empty, yet i can play the dvd just fine, and have used this dvd as my master in the past at home. i am using a dell 1300 inspirion with a nec dvd+-RW ND-6650A. Ihave two dvd's both appear as empty both play. I did try changing read speed not effect, do not know what else to try. Thanks for the help.
  2. dont know if this willhelp, but I can play both of these dvd's which are both homemade videos nothing copyrighted or copied. However when i use windows explorer it does not show any files on the drive.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd say it's an issue with the DVD drive in the new laptop
    If in doubt, Google it.
