I have video capture software that i can set the settings manually for in addition to the presets ofered. I need to capture in SVCD formast to create SVCD (PAL) compatible CDs later.
1) Should i choose constant or variable - If variable what settings for average bitrate and peak bitrate and GOP
2) Would it be better to capture in DVD and then rip to SVCD compatibility with say TMPEG quality wise though time consuming??
what's you capture card? mpeg2 hardware card like happauuge pvr-250?
Originally Posted by perfection
My suggestion would be to caputer it to the proper format you want FIRST so that you don't fiddle with the video more than you need to.
As Baldrick asked we need to know what capture device you're using to get more specifics in your situation. Most devices will have a setting specifically for svcd. On my old hauppauge wintv pvr250 it had three or four modes for svcd. It had "long play", "super long play" and "standard" modes. The differences let you record more per setting at the sacrice of quality.
As far as constant versus variable I generally don't worry about it. Though there are more picky users here on videohelp who could give you more experience on that topic than me.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 10:13 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 13:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 17:45 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 20:05
