  1. I am getting faint vertical wavy lines floating (lright to left) on my input from my video cable set top box. Can this be eliminated/minimized by software before i capture the same or later by running through a 'video cleaner (noise remover)' as my cable supplier is doing nothing about it from some time.
    I need to record in SVCD PAL format for playback on VCD and DVD players
    Feb 2004
    Australia
    Those line's are associated noise of combined signal ... as this is a "subscribed service" , it also contain's specific form's of encryption .
    These signal's do not affect normal output to tv , but will cause capture device's headache's ... it is best to treat the signal as in case "2" , as mentioned below .
    1:
    Check reception signal or topest box is tuned correctly .
    2: Normal method of capture
    Pass the cable to vcr .
    Video output from rca to capture device
    Audio output to linein (need rca to stereo headphone jack)
    You will find this help's .
    Rule : Never pass video + audio through capture device , this will degrade picture quality .
    3:
    If internal capture card , it may be in the wrong slot on motherboard ... change card's location and see if signal in capture has improved .
    4:
    Actual capture device at fault , replace .
    The use of software driven filter's is a "hit and miss" affair ... the wrong one used , not setting the filter strength to correct level , and on , and on ...
    Adding filter's during the actual capture to clean it up will tax the system , and dropped frame's may be the result .
    You really have to make sure you have the best possible input source , before taking action with video cleaning filter's first .
    Oct 2005
    Australia
    Just a question, how does different slot affect video quality? I've actually heard it before, but don't understand why. Thanks.
    Apr 2004
    Miskatonic U
    Distance from CPU or other high RF generating chips or interrupts that share with the slot are two reasons. The PCI slot nearest the AGP slot can be a problem.
    Read my blog here.
