I burned my AVI file on a DVD but at the end of it, when I play it on a standard DVD player I can only hear the sound. While I first see the first 3 seconds of the film and after that I can only see a green screen.
In AVI2DVD I've just chosen the standard options. In Encoding I only left unchecked Trelis and Extreme
It was a very simple film with no subtitles or else.
And one more thing, I was not even able to see the DVD MENU I created with the same software.
What's wrong?
does the dvd work on your computer with a software dvd player?
you could try other all-in-one converters like diko,thefilmmachine,divxtodvd and see if it works better.
and this is not dvd to, it is avi to. moving you. -
Originally Posted by Baldrick
I'll try with the other software too.
Is there a way before I burn a DVD to see the outcome and eventually check for any problem? -
Generate ISO only without burning it, and try something like Daemon Tools to mount the image and test that.
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
How can I fix a "interface not supported" error in avi2dvd?
By Han Solo1 in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 14:51 -
Help needed with Avi2dvd "hiccup" (muxed mpeg2 avail but didn't f
By bgart13 in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 17:54 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 07:05
