yeah i notice that alot of the DVD players dont support long filenames, and i had the dvp 642 i think it was about 11 characters it could handle up to and thats how i renamed the files on my HDD but its still renamed by the dvd player to some wierd filename and it throws it out of order which is hard when you got over 50 files to watch lol. I havent tried putting the ep # in front yet has anyone tried this yet??Originally Posted by jagabo
Results 91 to 120 of 716
I have noticed that the Divx files that have the .divx extention (Ver 6.0 I believe) will allways have the ~ in the name. Even a file name line 0001.divx gets displayed as 0001~1 or something like that. I renamed it to an avi extention and it was fine.
Because four letter extensions aren't allowed in 8.3 filenames. Just like computers in the old DOS days.Originally Posted by FFNogoodnik
I have noticed the same thing with the files not alpabetized. It obviously doesn't. If you put 1 on the drive first, 2 on second, etc, it shows up fine. FWIW....Originally Posted by Rowen
lol, I should have thought about that, being a child of those DOS days.Originally Posted by jagabo
8.3 only filenames has been a limitation since the first Divx DVD players so I doubt it will be fixed any time soon. The only player I know of (not that I know all that many) that supports long filenames is the Liteon 2002. Since it's such an obvious problem, and the fix fairly simple, I suspect it's a patent issue.Originally Posted by horo
awesome, i finally got my external hdd to work, thanks for everybody's help on here
Which external drive did you use and the HD size? Thanks
I have great luck with both Lexar 1 & 2 GB flash drives and an old 30 Gb maxtor & 80 GB WD drive in Adaptec ACS-100 enclosures. Both drives set as primary and formated as FAT 32, (thanks to nspavan who recommended Swissknife to format the drives, works like a charm). I've had no stuttering playing Divx off the HD's but had a little when I played a Mpeg off the flash drive.
i am using an old 60 gig maxtor with some generic enclosure i got off of ebay almost 2 years ago. i have occasional mild stuttering, but all and all i am really happy to have gotten this to work and with the set up.Originally Posted by Bodyslide
i also used swissnife to format to fat32. one complaint however, i was originally trying to use a 20 gig drive i had lying around. when i tried to reformat, everything seemed to have went well. but one i unplugged the usb and plugged it back in, i got the blue screen of death. this happened no matter what i tried, even when i put it in a desktop pc. i am unable to reformat it and it looks like it pretty much bricked the drive. so luckily this didnt happen with a decent drive. -
Sounds crazy but when this happened to me I swapped the USB from the front of the computer to the rear and it formatted without problem. Another idea is to connect the drive to an IDE port inside the case and try to format. If this fails try the jumper on cable select and lastly try a low level format using the drive manufacturers utility disk. I would use the DOS version if you can find it. Good luck!Originally Posted by youngthile
hi thanks for the reply, i tried connecting it to the ide port and got the same result. i also tried all of the different jumper settings and couldnt get anything to work. formating through dos may have some hope. altho, i am not too broken up about that drive. i wasnt using it before, and decided to use it because i didnt want to reformat my other drive. if i get a chance i will try it out.Originally Posted by weaseloso
dude Avoid Philips they make nothing but grabge players .I bet the DVP 5960 like the 642 comes with 3 months warranty onlyOriginally Posted by FulciLives
check the Pioneer DV-490V-S DIVX player
http://www.amazon.com/gp/product/B000EZKZLA/ref=pd_cp_e_title/104-6040047-4441543?%5Fe...lance&n=172282
it got a HDMI out perfect for your 51" TV you have -
"I bet the DVP 5960 like the 642 comes with 3 months warranty only "
If you buy it with some credit cards you get 2x free. Also, my card, Visa, offers longer guarantees for a few bucks. -
When I bought the 5960, I got the standard 12-month warrabty from Circuit City.
can someone inform me where i can find the latest firmware upgrade for the dvp5960? ive searched philips' website and google but no luck.
There is no new firmware as of yet for the 5960....
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=DVD_PLAYERS_RECORDERS...uctInformation -
Just because, well because I like toys, I was picking up some of the Sony MIJ that is on sale at Bestbuy until tonight July8, 2006.
I saw the 5960 and remembered from this thread that it works with external drives so I grabbed one. Did I mention I like toys?
Took a external 80Gb I'm not using right now, used computer management to remove the partition, SwissKnife to format as Fat32 and put some Divx/Xvids on the drive and tested,
Bummer! It worked and prompted to push the USB button, I was watchingsomething else, Then I got a unsupported USB message. Then it came back later with the Press USB button message.
Mostly it worked (Generic ME-320 USB2 Case)
To me it looks like one way around the 8.3 limit may be to put the video into folders by type such as Drama, Comedy, SStone (Sharon Stone) or KTurner (Kathleen Turner) etc. IOW Genre or by Star or Kids, Pops, Moms .
I have a spare 40Gb laptop drive, I may take home the external laptop drive case ($10) and see if it works with no extra power and no supported/unsupported problems.
Stray thoughts section:
No eject (open/close) button on remote?
Not very intuitive remote operation.
In contrast the Toshiba's I have that also play Divx/Xvid have much better remotes.
OTOH it seems to load Divx faster than the Tosh.
I Didn't find a way to move the zoom around the screen. IOW on the Toshiba if I zoom I can use the 4 arrow keys to move the screen up/down and left/right.
Cheers -
Works for me - when video bitrate is below 3.0 mbs. Does not play divx files having 4.0+ mbs.I use an A-Data My Flash 1GB USB 2.0 PD2 Flash Memory Drive and it works great!
Anybody from you, guys playing "high bitrate" divx files from USB port without stuttering?
ALL FILES PLAY WELL when put on OPTICAL DISK...
I capture video usind ADS Tech DVD Xpress DX2. Below are my capture settings:
640x.divx - stuttering
Video Resolution - 640 x 480
Video Bit Rate - 4,327,159
Video Frame Rate - 29.97
Audio Bit Rate - 192,000
Audio Sampling Freq - 44,100
720x.divx - stuttering
Video Resolution - 720 x 480
Video Bit Rate - 4,226,679
640y.divx - OK
Video Bit Rate - 2,501,765
720y.divx - OK
Video Bit Rate - 2,501,228
Best Regards
Kris -
I just bought this dvd player and absolutly love how you can play DivX/XviD through the USB port.
I have a 2G thumb drive that I can copy my AVI file into and watch. No need to burn cd/dvd.
Only problem that I have seen is that the sound seems to go out of sync. a little when watching avi through the USB thumb drive. Pausing and restarting seems to sync. it up again but it goes out sync. after a while. The sync. isn't too bad but its just enouhg to be a little annoying. Sync. is just fine when the same file is played through the cd. Anyone else notice this? Any way to fix it? BTW, my thumb drive is formated with the FAT32 FS.
Thanks. -
I've had no problem playing files from a USB flash drive. Fun capability.
Here is my question, and I'm hoping someone knows:
Is there ANY way to get this player to play something "HD"? Are there any HD DivX resolutions that will work? Or XVid, or anything like that?
I've tried a number of things, but I haven't had any luck yet. -
Any file over 720x480 will NOT play. I have tested them all and they all yield an 'unsupported resolution error'Originally Posted by jchansen
I bought the player yesterday and everything works fine except one. It plays xvid file through my PNY 2GB flash drive, but, whenever it plays hi-speed action, like war or fight scenes, it shows stuttering, and then go back to normal (plays fine) when it plays regular scenes.
I found that many people experienced stuttering problem. But, some experienced it with smaller cache/speed drive, like mine (flash drive), others had it with large size 3.5" higher rpm/cache drive. I don't know how to resolve this. I am planning to buy a USB external drive (WD, 60gb, no power supply, formatted FAT32) not just for this player though. Would it work with no stuttering?
Have it play via USB is important to me because I can save my dvd-r discs as well as time to burn. -
That is a bitrate issue. Many players stall on high bitrates. Any VBR encoding will have higher bitrates during action scenes. Reading off a hard drive (via USB) may or may not help.Originally Posted by kthan
It won't help with burn time, but you can always use and reuse RW DVDs or CDs.Originally Posted by kthan -
Then, even if I use other usb drive (faster rpm/cache), it will have the same problem, as long as I played the same or similar (VBR encoding) files? (does this problem have nothing to do with the type and spec of usb hard drive?) I had the same file and burned it to dvd-r. It played with no problem in this player.Originally Posted by jagabo
Is there a way I can change VBR encoding to the other setting, if VBR encoding (bitrate) is the reason for the problem? -
I don't know if the player has a USB 1.1 or 2.0 port. Since the specs only say USB I would assume it's 1.1. Although USB 1.1 has a theoretical bitrate of 12 Mb/sec, its real world throughput is about half that. A poor implementation might give you even less. So that would explain why the player has problems with certain files on a USB drive as compared to a DVD (with 10 Mb/sec or real throughput).Originally Posted by kthan
You could encode with a lower bitrate, or with the Min Quantizer value to a higher value.Originally Posted by kthan -
The player uses USB 1.1, which as mentioned above, sorts a maximum transfer rate of 12 megabits per second (1.5 megabytes per second). Even at half that transfer rate, that's plenty for most xvid files.
To give you an idea of how even USB 1.1 is overkill, an xvid file with a running time of 45 minutes (the length of a typical episode of a TV drama) with an average bitrate of 6 mbits per second (.75 megabytes per second)--half the theoretical max of USB 1.1--would have a file size of 2025 megabytes...far larger than anything you're typically going to play.
It's not a matter of transfer speed, it's just that the high amount of action requires a lot of processing power, which is too much for the cheap little processor in the DVD player.
Philips DVP5960 USB hard drive help
By JustinBaker in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Dec 2008, 15:03 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 14:58 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 21:28 -
Help with Philips DVP5960 and Sony Ericsson K800i over USB
By lucky23 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jan 2008, 05:36 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 05:39
