Results 1 to 15 of 15
    Jan 2006
    Can someone please help me out? The machine was working fine yesterday. I brought my DVD player to my room and test t and all of a sudden, watching a regular DVD, the video is all distorted. Just like if you are watching a PAL movie. Even the Avayon sign that comes out (no disc in dvd player) is distorted with 2 splits screen. So weird. I'm using a regular Sony TV (prob multisystem), do you know what I am doing wrong??
    Apr 2004
    Miskatonic U
    Have you plugged it in through a video player ? Could be macrovision
    Read my blog here.
    Jan 2006
    No , it's connected directly through TV.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What was the last disc you played in it?
    You mentioned PAL and Multisystem.....so....
  5. Banned
    Dec 2005
    Canada
    TV-DVD player connection or setup is faulty. Go back to previous config to test again and try in your room again once you know that equipment is OK.
    Jan 2006
    I played a asia backedup version DVD. I never performed that "multiregion" thing on the remote yet.
    It was playing fine upstairs, and I went up there to put a VCD in it, and it all of a sudden do that scrolling distorted screen thing.
    Jan 2006
    I brought the machine back to the living room in it's original configuration and I still get that scrolling blinking, screen. I have no idea what i am doing wrong. (
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Your machine doesn't happen to have an N/P button on the unit or the remote does it?
    Jan 2006
    No, i just checked....
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Strange indeed.
  11. Banned
    Dec 2005
    Canada
    check the manual troubleshooting section for reset procedure (to factory settings), call Avayon tech support...
    either you pressed some options unknowingly or your player is damaged
  12. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    It probably reset to PAL output.
    You need to figure out how to get it to NTSC output.
    The manual might tell you how to do it but you have to do it "blind" since you don't have a PAL TV unless you have a capture card on the computer than can be set to PAL then you can set it that way as it will show up on your computer monitor.
    - John "FulciLives" Coleman
    Jan 2006
    I called the tech support and they told me to get rid of the machine and they'll send me a new one. Now I have this extra machine to play, will someone please entertain me how I can reset this to ntsc?
  14. Banned
    Dec 2005
    Canada
    how some entertainment reading a manual... didn't tech support bother explaining how to do that?
    Jan 2006
    No, they didn't explain. I read the manual many times, all it said in the trouble shooting section was "reset the color system of the dvd player", but didn't say how.
    I already went to the dvd player's output option to select ntsc, but didn't work.
