  1. After burn a SVCD , I want do a test before wipe out
    a image file (.BIN) from my hard disk and see whole
    movie isnīt very practical ...
    Jan 2002
    cali
    Well i dont know what you use to burn svcds but if its nero or something of that sort use the "verify written data" check box
  3. Almost there , but I do use CDRWIN ,īcause Nero donīt work
    very fine with .BIN image files for me .
  4. There is a little program called CDCheck that will inspect CDs for errors as well as compare the CD to files in a specified directory. Might be what you're looking for. You can find it here:
    http://www.elpros.si/CDCheck/
    good luck
    baz
