I hope I am in the correct forum, if not I'm sorry. I have a data disc, 5.1GB size. I tried both Roxio 8 and DVD Decrypter to burn it unto a Verbatim DVD-R DL 8.5GB. Both burns failed and of course i'm out of two DL blanks. It ripped succesfully as an ISO with 3.5 DVD Decrypter. But I can't burn it. Help please and thanks all.
Results 1 to 9 of 9
So imageburn can write data? 5.1GB of data? Why is it different from Decrypter? Thanks again
It's made by the same person as DVDDecrypter but better at writing DL.
BTW...have you updated the drives firmware? www.rpc1.org -
Are you sure that your burner supports dual layer DVD-R? Some older burners only supports DVD+R dual layer and others (more old) does not support dual layer at all. Some models may add support of dual layer writing with a firmware upgrade.
This is not any video related. moving you to our Computer section.
You already have wasted 2 DL blanks, I suggest you save the folders to hard drive and burn with software as data if it is video create VIDEO_TS folder first or just burn the VIDEO_TS folder.
If your Computer Profile is current your Benq 1620 Pro is rated for burning DVD+RDL but not DVD-RDL.
https://www.videohelp.com/dvdwriters.php?DVDname=Benq+1620+Pro
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
Data disc
By jayronna in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Oct 2010, 14:53 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 04:10 -
How Do I Burn A DVD Data Disc ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 13:15
