I have been searching for a tool that I can change the kbps, I have a 5.4 gb movie I need to fit on a DVD and the video is already mpeg2
If it's already in MPEG-2 format, you need to re-encode it to reduce the size. This will also reduce the quality. You could try ReJig. If it's in VOB format as a DVD, then DVD Shrink is one method. Or you can use an encoder like TMPGEnc or similar to re-encode it. You may also need to use a bitrate calculator to set the bitrate to arrive at the right size. Look for them in 'Tools' to the left. <<<<<<
Looking for ts to mp4 conversion tool
By joel5632 in forum Video ConversionReplies: 15Last Post: 3rd Dec 2015, 04:49 -
Best tool for HD conversion
By carlmart in forum Video ConversionReplies: 27Last Post: 6th Feb 2011, 11:28 -
Best Conversion Tool?
By cdaz in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 19:06 -
restartable conversion tool
By djelimon in forum Video ConversionReplies: 5Last Post: 30th Dec 2007, 10:44 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 00:50
