ok, using TMPGEnc DVD Author to burn an iso image which i created using DVD Shrink.
in the lower left-hand corner of TDA, it says "Writing at 2x the sector 1483264 (total 2285881 sectors)." normally the number 1483264 increases about once per second until it reaches 2285881. this time around, however, the number stopped, as if the program is stuck on sector 1483264?
the program is otherwise working fine and responding properly. the timer in the lower right-hand corner is still counting so the program is not frozen. the disc that i created the iso from did contain a scratch, so the iso may be corrupted, but neither DVD Shrink nor TDA reported this.
i'm just gonna give it some time and see if it fixes itself. in the mean time, does anyone have any ideas or suggestions?
Results 1 to 1 of 1
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 00:00 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 14:23 -
Toast 9 gets stuck forever at writing DVD lead-out
By soundchaser in forum MacReplies: 11Last Post: 26th Mar 2009, 07:17 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 07:17
