    May 2006
    Belgium
    Hello,
    A fellow Encore user has the following problem:
    Whenever he wants to encode and burn a project, everything goes well right
    up to the point where the DVD has almost finished burning. Then he always
    gets the following error:
    "Unknown error File Error 331778"
    So far, he hasn't had any problems with his burn device, nor with the brand
    of blank DVD's that he's using.
    I can't find anything about this error in Google nor on the Adobe website.
    Has anyone had this problem before too?
    Lenny
  2. Member VERVE's Avatar
    Aug 2004
    Dubai, UAE
    I understand his frustration. If he changed any of the footage and encore failed to update, this might occur.
    best action: 1-make sure all assets are copied to the same drive (preferrably not the OS disk)
    2- replace assets in encore of all with the new copied assets on the non-OS harddisk. ( including footage, .psd, .jpg , wav ...etc...)
    3- save the project under a new directory and name
    4- check project ( correct any problems that the check has uncovered)
    PS: If none of this works, it might be a hardware issue.
    good luck,
    VERVE
    God Bless Lebanon...
