  1. I'm experimenting with a two monitor setup since a couple of weeks ago, and I would like to know if there is any way to set up a different wallpaper on each one in the extended desktop form. I just can't figure it out!, it seems that it has to be the same wallpaper on both screens.
    Any suggestions?
    1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
  2. Member SquirrelDip's Avatar
    Nov 2002
    Yes.
    Basically it's one wallpaper the total dimensions of both your screens. The offset between the monitors is show when you 'drag' them around in the screen properties.
    I believe you set the wallpaper to tile but it's been a while...
  3. Thanks guys, just what I was looking for.
    You rock!, I salute you!
