I am having trouble trying to capture some NTSC video tapes. In Australia, we use the PAL sytem.
I connect my VCR to my Digital Video Camera to convert the signal from analogue to digital, then connect a firewire from the DVC to the computer. The VCR is NTSC capable, and in my DVC's streaming menu, I select the input source as being NTSC.
However, when I play the NTSC tape and try to capture, I only get audio, with no picture at all. Can anybody suggest how I can get around this?
How many feminists does it take to change a lightbulb?
Is the VCR capable of ouputting a true NTSC signal? In other words is there a NTSC/PAL output selection. If you don't have that you'll have to get a regular NTSC VCR. Most likely you won't even be able to capture it as PAL because from ny understanding most don't do a true PAL conversion but output a siganl called PAL60.
Capturing video from Hi8 tapes
By Thanasis in forum Capturing and VCRReplies: 3Last Post: 1st May 2012, 01:21 -
How to play & convert Sony 8 mm Video 8 NTSC Tapes
By Richiegs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 19th Nov 2011, 22:13 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
Capturing Video 8-tapes
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 26th Apr 2008, 04:07 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48
