Is there any way to setup batch encoding of Premiere Pro projects?
I am using PPro 1.5 and need to export 4 projects. I wanted to set this up to run over the weekend. However, I can't find anything that would load/frameserve the prproj files the PPro creates and I can't load multiple instances of PPro to have them all running at once.
So, does anyone know of a way to have PPro open multiple projects and then batch encode/export them or is there some program that can load the prproj files and frameserve them to an encoder?
Thanks!
Melde Melda Vessė
Eruanna ar Eruntano Melda Eruntanohini
"May your days be bright and contact with stupid people limited." -
Ppro alone does not offer this function. however hardware like Matrox cards with their media tools encoder, which installs itself in ppro wil do this for u.
cheers,
VERVEGod Bless Lebanon... -
Can you tell me how to do this or where to find the info? I do have the Matrox hardware installed. Thank you very much
Melde Melda Vessė
No where in your comp. details does it say u have matrox installed. Cheers for the attitude though.
Batch encoding will happen not through PPro, but through your Matrox card..Have a look at the documentation...
I know you can batch export multiple filetypes from the same timeline (ie. .WMV, MPG, .AVI, .MOV), but i doubt you can export multiple projects...
Good luck!!!
Date Created - Batch Encode
By conandrum in forum Video ConversionReplies: 15Last Post: 14th Nov 2013, 16:57 -
Need To Batch Encode 78 MPEG2 Files
By hech54 in forum Video ConversionReplies: 7Last Post: 31st Dec 2010, 08:10 -
Feature REQ:True batch encode
By tszpara in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jan 2010, 05:30 -
Simple batch encode H.264
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 13:32 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 21:52
