  1. How do I extract the mpeg file from an already burnt SVCD.
    Vcdgear seems to only allow MPEG1 extraction.
    Is there a program that I can use to get the MPEG2 from the disc?
  2. I want to know this too
  3. what happens when you copy the DAT file from the CD to the HDD? Then just rename it to .MPG.
  4. Maybe this will help, and maybe not:
    http://www.vcdhelp.com/mpeg2tovcd.htm
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Aug 2001
    Finland
    There's no .dat file on an SVCD, the plain mpg file sits on /mpeg2 folder. Just copy it!
  6. u can use vcdgear to get the svcd off the cd.
    But why?
    Just copy to your hard drive.
    If it does not play, restream with merge and cut-
    MPEG 2 SuperVideoCD
    ShiZZZoN PzN
    Everyday is another payday and I am one step closer to becoming the one.
