  1. I know this isn't DVD related, but is there a program I could use to open an MP3 file and edit the file?
    I have a song that I want to cut off the end of it because there is a bunch of silence.
    Apr 2004
    Miskatonic U
    audacity and LAME if you want to save it back as mp3
    Read my blog here.
  3. mpTrim
    Originally Posted by mpTrim
    * mpTrim can trim MP3s - removing silent or unwanted parts.
    * mpTrim can adjust the volume of MP3s. Volume change can be manual or automatic (volume normalization).
    * mpTrim can fade-in/out MP3s (to fix abrupt beginning/ending).
    * mpTrim can clean-up MP3s and recover wasted disk space.
    * mpTrim keeps the music quality intact, no matter how many times you process an MP3, because it works directly in the MP3 format without having to decode/re-encode. That also makes it very fast.
    MP3Trim
    Originally Posted by MP3Trim
    mp3Trim is a simple and easy to use MP3 editor.
    Its main advantage is that it works directly in the MP3 format without having to decode/re-encode, so it is very fast and doesn't degrade the music quality.
    So, what exactly can mp3Trim do for you? mp3Trim can trim the parts that you want to discard. mp3Trim can adjust the volume - either manually or automatically (normalization) - for example, to amplify those pesky MP3s that sound too low. mp3Trim can fade-in/out (to fix abrupt beginning/ending). mp3Trim can clean up your MP3s and recover wasted disk space.
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  4. Member Safesurfer's Avatar
    Mar 2004
    Also Mp3DirectCut.
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  5. Here is a new question, is there a program I can use to put two mp3 files together as one?
  6. Member Safesurfer's Avatar
    Mar 2004
    You can do it with MP3DirectCut. Just launch 2 copies of the program, you can use cut and paste to append selections between the 2 copies of the program and save out to a new file.
  7. Mod Neophyte redwudz's Avatar
    USA
    What do you mean by 'put' together? You mean cut and paste parts? Or blend or mix two tracks together to make one?
    Most audio editors that accept MP3 can do either one. I use Audacity for this.
