Let's say I have a 640x480 video but there are black bars that provide what we call "letterboxing". Let's also assume I like wide-screen videos so I expect to see black bars no matter what. I can do one of the following:
1. Live with the black bars (because they'll be there on my 4:3 TV no matter what and I expect black bars).
-or-
2. Crop the top and bottom. Let's say I find that 100 pixels at the top and 100 pixels at the bottom should be removed in order to have a wide-screen video (so on my Mac it has no black bars). So the next question is: What pixel size should I use? 640x280 or 640x480?
Final "bonus " question: Can I use the iPod H264 setting and still crop or must I do the cropping in Xvid or Divx? Where will I maintain the best quality?
Thanks!
Results 1 to 10 of 10
2: While black bars don't require much of the available bitrate, including unneeded black areas does waste some resources, which could have been used to improve the video of the main area. So I would go with cropping.
Bonus: Best quality is with all the alterations and encoding in one step. Check the Crop section in the Filters tab.
On the website it says to scale to 320 width for H.264 iPod encodings, with whatever height corresponds to the aspect ratio of the movie. The cropping is done before scaling, so the crop values are applied to the source material. Does that answer your question?
For wide-screen videos I do the math and, following the rule of 16's, keep the proportions correct while maintaining a total pixel qty of no more than 76,800. Usually this is 368x208 or 400x192 or 416x176 depending on the proportions of the source.
So, if I understand you, I can calculate the desired size by -first- subtracting what I am cropping (ie, 480-200=280) and then use the 640x280 as the source size; I'm using the 640x480 source I mentioned in an earlier post. This would yield a 416x182 calculated reduction - 416x176 being the closest legal size.
Nothing to do but test it, eh?
Thanks!
As I understand it, since cropping takes place prior to resizing, the target size is independent of the other values.
So the process is this:
640x480 source / 100 pixel bars -> cropped to 640x280 -> resized to chosen size (416x176) -> encoded to final encoding scheme.
i.e. decode -> crop -> resize -> encode.
So it does not matter how many pixels you cropped, the final size will be what you set it to in the video tab. So for instance, if you have 640x480 mpeg and you set it to cvonvert to a 640x480 h264 with a crop 240 from top and bottom, you would end up with a blank 640x480 clip.
Originally Posted by rumplestiltskin
"If you use h264: don't change the image width"
I believe the warning relates to the 320x240=76,800 total pixels limitation. Many of the apps for converting to H264 make the (erroneous) assumption that 320 wide is the issue whereas it's the total number of pixels. However, I'll give it a try again and report back. Thanks.
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 21:42 -
Convert 16:9 to 16:10 with letterboxing hardware
By JesterMania in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Dec 2009, 14:29 -
Letterboxing video for youtube
By cwy in forum Video ConversionReplies: 5Last Post: 2nd May 2008, 08:35 -
Avisynth resizing/letterboxing problem
By czerro in forum Authoring (VCD/SVCD)Replies: 3Last Post: 3rd Jan 2008, 14:29 -
removing letterboxing on MPEG2 files
By hellsaviour in forum MacReplies: 3Last Post: 13th May 2007, 14:17
