I have tons of pre-installed wallpapers and ringtones on my Motorola V330 that I'll never use. If i choose a wallpaper/ringtone I installed it gives me the option to delete it, but on the pre-installed ones there is no delete option that i can see. So is there anyway to delete this files, so that I can free up space and add files that I'll actually use?
What We Do In Life, Echoes In Eternity....
I've deleted several on my Motorola MPx200 via Microsoft Active Sync and my PC....but mine has Windows.
If they're embedded in the phone's ROM, then no, you cannot delete them, and you will not free up any space by doing so.
If you need more "room" on your phone, get a phone with an expandable memory slot
Cheers, Jim
My DVDLab Guides -
run it over w/ a car -- deleted !!
over the air antenna w/ pre installed wiring from cable
By carlos28355 in forum DVB / IPTVReplies: 4Last Post: 26th Sep 2011, 00:10 -
Pre-installed Vista on Laptops
By cyflyer in forum ComputerReplies: 31Last Post: 3rd Feb 2009, 05:57 -
Help installing xp on HP dv9910 laptop w/vista pre-installed & sata hd
By freebird73717 in forum ComputerReplies: 5Last Post: 14th Sep 2008, 20:54 -
Pre-installed viruses from China
By cyflyer in forum ComputerReplies: 5Last Post: 15th Mar 2008, 08:05 -
Creating Animated Wallpapers
By Carrie-Ann in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 03:51
