Could someone tell me how I can record from my hdd to dvd. I have the JVC -DRMH30. I have tried following the manual but I can't get it to work. I am trying to transfer a recording I put on the hdd to a dvd-r disc.
Do you have a DVD burner? DVDDecrypter or DVDShrink should work if you do. Check http://www.bensbargains.net/ to find high quality DVD burners such as NEC, Pioneer and BenQ if you'd like to get one if you don't have one. You might also check http://www.acortech.com/.sc/ms/sch/ee?search=Nero&go.x=0&go.y=0&go=go to find Nero 6.6 for $5 and download latest update for Nero 6 from http://ww2.nero.com/enu/Downloads.html if you don't have burning software.
Noon: How do I tell WMC to record to another HDD after primary is full?
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 17th Apr 2011, 12:22 -
Thomson Scenic DTH8550 wont record on HDD
By Chasser in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Nov 2010, 19:33 -
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 13:09 -
Can a HDD MiniDV record a DVD by connecting with a DVD player/recorder?
By coody in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th Jan 2008, 09:01 -
how to record from the HDD to a DVD+RW disk, using a Yamada DVR-9300HX
By The Muddler in forum DVD & Blu-ray PlayersReplies: 7Last Post: 1st Aug 2007, 13:00
