Hi!
Sometimes when I try to encode a DivX file to MPEG-1 using TMPGEnc it just "loses" the sound.
This just happens with most of the files, but some DivX files with exactly the same properties works just fine.
I have tried to change the settings in TMPGEnc a little to try to get sound for the weird files, but to no avail.
I've also tried to encode just the audio, but all that happens then is that I get a very quiet MPEG file.
Can someone please help?
//Foppa
Results 1 to 1 of 1
Sound wont work on KWORLD DVD Maker USB 2.0
By BiggerJim in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 07:06 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Why doesn't sound work when playing through local network?
By Obamargarine in forum Software PlayingReplies: 1Last Post: 23rd Feb 2009, 14:39 -
best sound program to work with Vegas?
By templedog in forum AudioReplies: 4Last Post: 1st Dec 2008, 14:26 -
no sound when i captured from dv in adobe prem cs. even hd didn't work
By cannibalcam in forum AudioReplies: 7Last Post: 5th Mar 2008, 08:07
