Is any hot burner sold region-free (like the NEC 3550 or BenQ DW1655 w/lightscribe) or is it necesary to flash them all to be region-free after purchase?
Any idea which hot burner would be most compatible with older standard stand-alone DVD players?
I want to be able to create DVDs that will play on the maximun number of stand-alone players.
AFAIK, any burner will have the regular region codes installed. You would need to flash it to change that. But that only applies to commercial DVDs that you are playing, not burning. All burned DVDs will be region free, unless you purposely put in the region code when burning.
Most any of the popular burners will burn a disc that is compatible. You may have to use BookType/BitSetting for older players for the best compatibility. If you look to the left in BD,DVD Writers you can see that as a search item for the listed burners. <<<<<< The media is usually more important than the burner for compatibility. TY media is one of the best.
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 01:20 -
are there any blu-ray players that can be made region free for dvd's?
By CODEWERKX in forum Newbie / General discussionsReplies: 2Last Post: 25th Sep 2009, 14:26 -
Soniq DVD players region free hack
By sshipway in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th May 2009, 17:58 -
dvd recorders standard/multisystem/region free and international
By victoriabears in forum Newbie / General discussionsReplies: 0Last Post: 24th Jan 2009, 14:53 -
Question: Region Free DVD Players
By SentaiFan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th May 2007, 04:07
