I tried backing up a movie with dvd shrienk and I got errors, so I used dvd decriptor instead, but didn't realize that one doesn't have a burn option. IS there an easy way to burn to disc?
Also I thought the purpose of dvd shrienk was to "shrienk" a dvd down to fit on a standard dvdr? After backing up many discs for the first time I got an error saying it was not going to fit on the dvdr and to set to auto (which it was) Did I do something wrong, again I thouhgt it always shrank it to fit a disc. How can I get it on there?
I wouldn't recommend shrinking a disc unless you are only saving a few MB of information. Quality is significantly reduced. My recommendation is to use dual layer discs. Since you are backing up obviously critical information you should at least back it up with the same quality as the original and not destroy it by shrinkage.
I use Nero 7 for all my burning needs. -
I don't care shrienking these, they are just baseball games, not movies. But the thing is it's not even letting me, did I miss something?
so if I launch nero will it burn the dvd decrpited on to disc the same as it would come out of dvd shrienk? (this one fits) -
Yep! just select DVD Video in Nero and find your decrypted folder. Drag/Drop/Burn.
How long should a DVD burner last?
By Regor21 in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Sep 2010, 14:31 -
Rendering taking too long- How to speed it up? (Sony Vegus movie)
By Entry in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2009, 01:47 -
Long videos in a dvd
By valtea in forum Authoring (DVD)Replies: 7Last Post: 20th Mar 2008, 12:21 -
How long is your "Live Free Die Hard" movie on DVD R1 ?
By NiteLite in forum Newbie / General discussionsReplies: 4Last Post: 1st Dec 2007, 17:27 -
Audio popping with long movie's
By md0234 in forum ffmpegX general discussionReplies: 0Last Post: 20th Oct 2007, 13:50
