I have a movie in 1080i with a file extension .ts. Firstly, what file type is that? its not a file extension I'm familiar with. My 2nd question is how can I convert this file to the highest quality file type that will play on xbox 360 ( streamed through media center )? I'm guessing the format is wmv-hd, Is there a guide I can follow?
Thanks in advance
Kev
hdtv transport stream
you could try hdtv2mpeg2 and windows media encoder or wmnicenc -
Thanks for the reply. Would this give a HD output? I'm guessing not as I don't think mpeg2 is HD. I want to end up with wmv-hd. Is there a way?
http://www.avsforum.com/avs-vb/showthread.php?t=633144&page=1&pp=30
or convert to wmvhd with wme. -
Baldrick, or anyone, I'd like to ask a question here - somewhat related to this topic.
What tool(s) could be used to down-convert resolution from a HD-DIVX to DVD resolution(s)?
I've been trying to search for a solution for this for some time, but not having any luck.
Thank you.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
kevlar: tsconverter might also be useful.
painkiller: no, it has nothing to do with ts to wmvhd streaming video. make a new topic instead...hddivx to dvd should be same as divx to dvd. -
Thank you.
Will do.Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.)
How do you convert HD 1080i TS file to a file that Vegas accepts?
By SoccerLover in forum Video ConversionReplies: 40Last Post: 12th Nov 2010, 13:59 -
Cannot convert 7.5 GB mkv file to wmv?
By killazys in forum Video ConversionReplies: 1Last Post: 17th Feb 2010, 19:07 -
how to convert a 720p MPEG-2 file to 1080i?
By cal888 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 21:33 -
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?
By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 22:04 -
By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 17:53
