my firend have a mac pc and i gave him some anime on mp4 format and he said he cant watch it, is there any program out there that he can use?
You ought to know, "MP4=MP4" isn't the way to think about this. Just like MPEG2 has "Profiles" and "Levels", so MP4 has "Profiles" and "Levels" and "Versions".
The Most common ones are:
Simple Profile (@ Main Level) (from MPEG4 v1), Advanced Simple Profile (from MPEG4 v2), and AVC/h.264 (aka MPEG4 v10)
Macs use Quicktime mainly. Quicktime understands SP and h.264, but not ASP.
DivX/Xvid/3ivX MP4's can be either SP or ASP. That's likely the problem right there.
Your best bet is something like ffmpegX or VLC. Or have your PC friend convert it to something your Mac can understand. Or watch it on a PC (sorry Mac fans).
You may have similar problems with Audio, re: M4A/AAC LC vs. M4A/AAC HE. There are other codecs that might give you trouble too.
Scott -
Yes, VLC is great. Also MPEG Streamclip will play (and convert if you wish) many formats.
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
How to view other .MP4 vids in mY Sony H20?
By cool6969 in forum Video ConversionReplies: 0Last Post: 10th Oct 2011, 03:04 -
hdr-cx115e live view: direct connection to tv or mac --> tv??
By paolocardelli in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Oct 2011, 18:27 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 22:24
