Hey guys, I just started playing with the new Nokia 6165i from Sprint PCS, and I have a question for some of you who might've done the same. The phone supports .mp3 and .aac, but when I send .mp3's and/or .aac files to it, it says "File Not Supported". What's with that?
If you check out some of the ringtones that it comes with, they have .aac extensions.
I notice that all Sprint phones have the same problem, I guess its there way of getting you to buy ringtones rather than creating your own and sending them wireless via Bluetooth or Infrared. (By the way, I've tried both of the methods just stated)
Is there any way of bypassing this, or at least somehow getting custom made ringtones from my computer to this phone.
On another note, I previously owned a Nokia 6255i from MetroPCS, and it worked flawlessly with .mp3 and .aac ringtones. I send them from my PC to my phone via USB Bluetooth Dongle. I've also been able to send many other phones ringtones from my 6255i, including Nextels, Cingular Wireless, and MetroPCS. Just no luck with Sprint. Why is this?
Thanks in advance!
"The statement below is True,
The statement above is False" -
- Bump - Bump -
Anybody?"The statement below is True,
I know that inorder for me tosend mp3s to my motorola V330, the must be a MAX 128 and 22000Hz....otherwise I get that same error
What We Do In Life, Echoes In Eternity.... -
Ok, I'm going to check into that. Thats make sense, I can see how that might give it that error. I just assumed that all Nokias can take mp3's no matter how they're encoded, only because I've tried sending all kinds of different mp3's to several Nokia's (Just not Nokia's on Sprint PCS) and they send & play fine.
Thanks. I will try that tomorrow"The statement below is True,
Editing ringtones with Audacity
By siluet in forum AudioReplies: 3Last Post: 14th Sep 2023, 03:33 -
Creating .mp3 ringtones using Audacity
By Hittz in forum User guidesReplies: 11Last Post: 17th Aug 2010, 16:11 -
Getting Ringtones
By BLSAMPLES in forum AudioReplies: 12Last Post: 8th Jul 2009, 13:00 -
How to create a AAC File for ringtones
By mlong30 in forum AudioReplies: 9Last Post: 19th May 2009, 12:38 -
Nokia 6030 Ringtones
By strongbad in forum Off topicReplies: 2Last Post: 5th Jun 2007, 10:24
