Hi all, first question on the boards,
I'm new to making videos in Vegas 6.0, and I have made a few successful videos in the past, and had an issue with the audio. For some reason when I go into the custom rendering options, I can select the Divx video format just fine, but when I choose the audio format, under Mpeg-3, it is only letting me select a 56Kbit/s option. I would like to have a 128Kbit/s rate, and was wondering how this is possible, whether it be via plug-ins or downloads or whatever.
Thanks.
I have templates for up to 320kbps CBR, as well as 3 VBR templates if I choose to render mp3 as standalone audio, however as with you I can only go up to 56kbps if I choose it as part of a Divx encode. That said, if you install LAME you can go up 320 inside Divx from Vegas. It must be the same licensing issue that sets the same limit for WMP out of the box.
Read my blog here.
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 15:06 -
sony vegas pro 8 rendering wont render video just audio and text
By bahlue18 in forum EditingReplies: 6Last Post: 12th Apr 2011, 08:31 -
Cannot render to widescreen in neither vegas 7 or 8
By 2prfm in forum Video ConversionReplies: 1Last Post: 7th Sep 2010, 09:38 -
Vegas Batch Render?
By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 03:42 -
Vegas Render Still Sequence
By vegasarian in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 08:39
