Hello,
I'm trying to backup the movie Hostel. I'm using Mac The Ripper and DVD2ONE. When using MTR an error message comes up saying that the vob has deliberate bad sectors. It then asks me if I want to delete the vob or pad it. I've tried to pad it. Then I go to use DVD2ONE to compress it and it stops processing about half way through. This is a Sony movie and I heard that this is a new copy protection technique Sony is using. Any suggetions?
I'm going to be smug and suggest you wait until there are some used copies that are available cheap and get your backup that way.
But you also could try converting the ripped VOB set to DV and then re-encode the MPEG. -
Which version of MTR?Originally Posted by dylanb2cm
Hostel has been successfully copied using the following steps:
Rip with MTR Version 3 release 13d (latest beta)
Set DVD2OneX Version 2 to a movie only, remove the 52 empty cells and proceed.
You should have a disc that plays on your Mac and set top player
How to backup DVD movie to DVD-9
By metra in forum Newbie / General discussionsReplies: 7Last Post: 5th Feb 2010, 03:09 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 15:55 -
trying to backup the simpsons movie
By etrin in forum DVD RippingReplies: 30Last Post: 12th Oct 2008, 08:14 -
Goal 2 movie backup
By paul_pompey in forum DVD RippingReplies: 2Last Post: 2nd Feb 2008, 04:54 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
