Hi,
Please help me in learning how to create VCDs after downloading video(with audio) files from internet.
I have Adaptec, Nero, RealonePlayer and of course CD-RW.
Your help is greatly appreciated.
You will notice that on the menu to the left there is a link that says "How To: Convert". Follow that. You will need to convert whatever you have to VCD compatible MPEG.
A little bit further up, there is "How To: Author". That will tell you how to create/burn a VCD from your MPEG files.
Regards.
Michael Tam
w: Morsels of Evidence
AVS File Steps
By sambat in forum Video ConversionReplies: 23Last Post: 16th May 2011, 13:27 -
First Steps In Premier CS4
By Sundayarak in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2010, 19:09 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01 -
Which steps should I use?
By Belfour in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 09:33 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 12:00
