I bought a nifty little tool kit that has some cutters (total crap!), a coax (RG59 & RG6) stripper (SLICK!), several F-Type connectors, and a crimping tool.
I know, I know, the compression connectors are vastly superior, but the tool is WAY too expensive.
Anyway, the directions say to flare the shielding on the cable and fold it back prior to putting the connector on.
Am I supposed to flare & fold just the braided shield, or the foil shield as well?
I wanna make sure I get this right THE FIRST TIME, because I don't have a lot of cable to work with where it comes out of the wall.
TIA!!
Results 1 to 9 of 9
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
BTW, this is the kit:
kit description is here:
http://www.datasharktools.com/view_tool.php?id=489&pid=271"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Check me if I'm wrong here Sandy, but isn't that a crimp connector kit?
Fold back the outer sheath? I don't fold it, I cut it off. I expose about a 3/4 of an inch of the center wire. I strip about half of that. Then, I twist the connector over the whole thing. I finish by using the crimper in two separate spots on the connector. I don't do any folding or flaring. -
who in the hell is "Sandy", and yes that's a crimp set -- the compression tool is too expensive!
Thanks for the link Mr. Dweezel -- you da man!"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
good link and proper way to do it ... if you dont 'flare' or fold back the shield you dont get a good ground connection (the member above who cuts it off is not doing a good thing) ...
I feel so cheap
I don't have any of the fancy strippers
All I have are my trusty old Ideal 30-433's
Not having been taught the correct method, I first cut the cable to size. Then I strip off the outer sheath about 3/4 of an inch to match the length of the inside of the crimp on the fitting. Then I fold back the braid over the outer sheath. Then I break from tradition. I strip off the foil and the inner insulation all the way back to the point of the folded braid. I then push, shove, cuss, jab myself, poke myself, wiggle and twist until the fitting bottoms out and the white is at the proper place in the fitting. And then I crimp the hell out of it all nice and neat. I wipe the sweat from my forehead on my sleeve and the blood from my fingers on my pants.
A good mechanical connection is a good electrical connection. You could swing like Tarzan on one of my connections. And I always use plenum rated cable. (You never know)IS IT SUPPOSED TO SMOKE LIKE THAT? -
Oh... fold back the braiding! I get it. I thought he meant fold back the plastic sheath. I understand now. I do this myself.Originally Posted by BJ_M
What is a compression tool? -
the compression connectors are fancier (and unquestionably better) F-Type connectors compared to the crimp-on type I used.
they're also more expensive and the tool used to put them on is ******* PRICEY.
They are waterproof, and one type of compression connector is shown in the first example in the link that Dweezel posted."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
CATV to S-Video?
By MrLoyyy in forum DVB / IPTVReplies: 2Last Post: 28th Dec 2011, 20:43 -
compatible connectors with DVI-D single link
By ecos in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2011, 00:45 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 13:09 -
right angle SATA connectors
By rallynavvie in forum ComputerReplies: 22Last Post: 31st Aug 2009, 07:42 -
cutting off unneeded psu connectors
By zeppage2 in forum ComputerReplies: 4Last Post: 2nd Nov 2008, 17:58
