Hi all, I have recently uninstalled this program and re-installed due to a new hard drive. Since then, this program won't encode divx or xvid files, I'm pretty sure I have the codecs installed as they can be viewed through media player.
Funny thing is that NeoDVD used to make dvd's of any file format I threw at it.
Now I'm finding that I have to encode to mpeg2 before I make a dvd. I thought neodvd had the best encoder.
Can someone help me?
If not, are there any guides for avi2dvd to help with the menu's etc. Is there any other software similar to neodvd?
It's not a Black and White world, to be alive the colours must swirl.
And I believe that maybe today, we would all get to appreciate.... The Beauty of Gray.
- Ed Kowalcyk (LIVE) - -
Same thing here , though I have not struck your issue with neodvd ... I have not been able to get it to encode into any avi format ... just all dvd format's ... got other tool's for that anyway ... just it came with my dvdeasy pci card .
As for being the best encoder ... well ... it was not free , so it dosent even rank up against bbmpeg ... my favourite for all supported dvd format's that ifoedit will accept without question .
As for avi2dvd , not sure on guide's around the place ... and this program is packed ... a basic guide may exist , but one the gose too the bone most likely dosent as yet ...
So I'll have a crack at that menu thing this week and see ... did a fine job of the avi conversion , very quick and good result's .
Though as the saying gose "rubbish in , rubbish out" . -
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 10:03 -
Making a DVD compilation - MPEG2 to DVD problem
By Dingler in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2009, 14:40 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 17:39 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
